Flash player error – updated version still not supported
I have update my adobe flash player each time an update is available. But now there has been a recent problem with it and it cannot seem to play few of the files on some web sites which suggests that you need to update your adobe flash player. I need to know how to get rid of this problem and play the files effectively.
Jeremy Ngo.
Answered By 590495 points N/A #110366
If your Adobe Flash Player is very well updated but it still can not play any online videos on some web sites, it is possible that there is an error in the hard drive’s file system and corrupted some of the application’s files. Uninstall Adobe Flash Player from your computer then check your computer for any possible errors.
Use a disk utility application to check the system. Download the latest version of Adobe Flash Player at:
The latest release is version 11.2.202.233. Just follow the onscreen instructions when downloading the installer and on how to install it on your machine.
After the installation, try visiting some web sites again and then play a video.
