My Flash Player is acting strange lately so I decided to uninstall and reinstall it to see if flash games will now run and while I was installing it there goes this Flash Player encountered error with NO information is available.
Flash Player: The installation encountered errors: No error information is available.
Thanks Adobe! How am I suppose to fix this if there is no information available?
Flash player installation encountered errors
This error is quite often occurs which is a permission error. I mean in order to install this flash on your system you need to have the administrative permissions if you are not using system is not in domain. If your system is in domain then you need to have the domain user administrative account as the administrative rights doesn't work for your system.
So make sure you have any of those two to uninstall the flash from your system. Follow the uninstalling flash from your system instructions which will be available online. And then try to install those on your system. If it doesn't work please let us know.
