Hi, I am an Windows XP 64-bit edition. I am using some video editing software. These software needs Windows 64-bit edition to run perfectly, so I need to keep Windows 64-bit edition. I also need to update all of my software regularly. But some of my software isn't responding like before. Such as the Flash player.Â
points
Flash player isn’t working with windows XP 64-bit edition
Adobe Flash Player and all the other softwares are supported to be run on 64-bit OS. Only in rare case, you’ll face problem running 32-bit programs on 64-bit environment. Nevertheless, it’s recommended to use 64-bit edition of any software when you’re on 64-bit OS.
Download Adobe Flash Player. Install it and see if it works fine.
According to Adobe’s wiki, their Flash Player doesn’t support Windows XP 64-bit. You have to get Windows 7 64-bit to work with Flash Player.
There is not any type of Flash Player for the Window XP 64 bits. So no need to worry, just update the window to window 7 or 8. And then install the flash player and it will work fine. Otherwise try to uninstall and then install again the Flash Player that is for 64 bits OS.
