jerrytoms
1170 points
Posted on - 07/12/2011
Hello geeks,
I am at our office laboratory to do some experiment, I decided to look unto the internet for some demonstration video, I found one video that would be helpful for my task, but when I am about to play the video, an error message appeared on my screen, please see below the screen shot generated by flash player.
Flash Player required to view this content.
An older version of Flash Player has been detected
on your system. This content will not display correctly
without installing the latest version of Flash Player.
I am not good with computer, but I am trying my best to understand some points, as I read on the error, it needs for me to install a new version of the adobe flash player, but my problem is, the computer that I am using has a restriction on installation, my question here is, can I still install this application in spite of the limited access of my computer?
Please advice me, thanks.
Dear Jerrytoms,
Your system required latest flash player and you must install the latest version of flash player to view that video. There are two possible solutions for your problem.
Ask your system administrator to give you permission for installation for some time and I think he will do.
Second, you can download and use portable flash player. A portable flash player not required installation; it is a package of pre-installed and active software. We can say that ready made software. Here is a download link of portable flash player.
Just download and play your required video without installing.
Hope your problem will be resolved.
Take care.
Benth
You can solve this problem through installing adobe flash player. Simply you can do it by follow these steps.
Go to https://ninite.com/. Then If you use Internet Explorer to browse we please select Flash (IE), select other one for other browsers.
Then scroll down web page and click “Get Installer”.
After download this file, double click on it.
After this installation you can watch video on your web browser properly.
Thank You.
