Flash player updater facing an issue.
Hi
I am getting error in flash player. Update services:
Flash player updater issue.
Error Report Contents
The following files will be included in this error report:
C:DOCUME~1OwnerLOCALS~1TempWERe3f4.dir00FlashPlayerUpdateService.exe.mdmp
C:DOCUME~1OwnerLOCALS~1TempWERe3f4.dir00appcompat.txt
        Close
Best Answer by p Vhilary
Answered By 0 points N/A #154102
Hello Rabbeca Michel,
To fix your issue, you will need to uninstall the Adobe Flash Player and make a clean install of it by downloading the latest stable version. You can find it here: Adobe Flash Player Download. For uninstalling Adobe Flash Player you might want to see this link: How to Uninstall Adobe Flash Player. I hope that this solves your problem.
P Vhilary
Answered By 0 points N/A #154103
Hello Rebbeca,
To get rid of this error message please follow the simple steps mentioned below:
1. Uninstall flash player from add / remove program
2. Go to C:program filesAdobe and delete the Adobe flash folder completely.
3. Go to your username folder, un hide the hidden folders and delete the Adobe flash folder.
4. Reinstall the Adobe flash player.
Everything will be good then.
Thanks
