Flash plugin crashed, how to repair it?
Hello Whizzes,
I was stuck up with an error message while I try to play a flash movie. I tried the very common methods like restarting, trying after some time and rebooting the system but nothing seems to fix my problem. How do I fix my problem without reinstallation? Please help me. Your help is great.
Whoops
The Flash plugin has crashed.
Please log in again
Answered By points N/A #166597
Flash Player is one of the most important assets in web browsing. It combines with the browser and makes it possible to play many media files online. Though it works fine, sometimes it might crash.
In such case, you have to uninstall the older one, install the latest one.
  1. Go to Control Panel >> Programs >> Programs and Features.
  2. Right-click on “Adobe Flash Player” and select “Uninstall”.
  3. Exit all your browser.
  4. Download Flash Player.
Now, try to open the content on the site.
If it still faces trouble, you have to update your browser. Download the latest version of your browser. As you didn’t mention which browser you’re using, I’m giving the most popular browser’s download page.
Now, your problem should have solved.
