Flash presentation free sample file
Hello guys!!!!!!!!!!!!
I have learned make flash presentation recently. Now I want some flash presentation free sample file so that I can make flash presentation easily.
Can anybody help?
Can anybody help?
Hello Zeb, thank you for bringing this enquiry here. I made some research about free samples of flash presentation on the internet. Below are links where you can get free samples of flash presentation:
http://www.nextwavemultimedia.com/html/flashpresentation.html
https://www.freelancer.com/work/free-flash-presentation-sample-fla/
https://www.ispringsolutions.com/ispring-pro
I hope you benefit from these sites and that you find what you're looking for.
There is a software named Powerbullet Presenter which is specifically used for flash presentations. It is an really easy software such that you can drag and drop stuff to make animations. This is an really interactive software which also enables adding sounds clips to it. Its freeware you can Google it and download it for free
