Is flash Server side PDF creation possible?
Greetings everyone. As simple as the title says, I just want to ask if a flash server side pdf creation possible? I mean, would one be able to do so? This is just for research purposes so I would gladly welcome any comments and suggestions along the way. Thanks a lot guys.
Best Answer by Huffman Serafin
Answered By 0 points N/A #150470
Hi Leigh Slayton,
Yes it is possible, you can create a pdf file online using flash at your ease, I am using the adobe create pdf website in order for me to write stories and tutorials for myself in pdf form. It is good and user friendly, the thing is, it has the cost. The pricing will range from $10/month (monthly) and for about $8/month (annually), it will be costly enough for adobe has pride it their products.
Answered By 0 points N/A #150471
Hi Leigh,
Yes its possible to create a flash server side PDF. There is a software created for that purpose which is called, WebORB PDF Generator.
To serve your interest about Flash server-side PDF generation, you can use this software for your research purposes.
You can have more information about the product here.
Answered By 0 points N/A #150472
Yes,  the best way is to install a PDF generator script on your server, we call it a server side script than can handle your PDF generation on your server. There are some applications exists also compatible with flash server such as JSPDF that's written in JavaScript, and WebORB. For WebORB you need to purchase a license but it comes up with a full installation guide and support.
