I’m trying to watch Flash videos that have a table of contents. The problem is that each time the formatting of the table of contents is all stretched out. An example is below.
Why is this happening?
Flash Videos With Table of Contents are Stretched
Hello Dear,
The problem that you have encountered is just because of the out dated version of your flash player. You can simply update it from internet. Although many flash player failed to buffer or you can say stream the multimedia file properly. So, all you need to do is the using of best flash player. Here is a recommendation for you:
It’s named ‘FLV Flash Full screen Video Player”
The features include:
1. Support *.flv, *.mp4, *.3gp, *.m4v, *.f4v
3. Playing video in full screen mode
4. Automatic accept ratio
Thanks for having your time
