Flash Player Disabled: Trouble opening some websites
I already installed flash and still cant see images and cant here any sounds error….
been watching youtube and other sites and got the same problem.
If you have installed flash player and still you can't see video and did not hear any sound there must be some problem in your flash player or your installations. What you have to do you have to open youtube and select the any video. try to play any video and if it does not played then you have to update your flash player. Youtube display a link through which you can update your flash player. what you have to do. click on the link and get for the latest flash player. which is available. Now again open youtube. you will find the video played correctly. thanks
