Flashback Virus in Apple can be fixed
Hello Braxton,
There are several ways to remove Flashback from your Mac and some of them are quite complicated or simply download Apple's new release of Java security update that automatically removes the Flashback trojan. It is recommended for every Mac user to install this update even if you have just previously checked your system. To get the update, simply download the update Java for OS X 2012-003 from software update within the apple menu. Installing this update requires no manual removal and it further protects you from future potential threats.
I hope this helps.
If you are sure that your Mac computer is infected by the Flashback virus, you may try removing it using Norton Internet Security. It has a Mac version for users who are using Mac OS X PCs. Other antivirus programs are also listed below so just check them out and try using those that supports your operating system.
