Flex mobile test driver for apple iOS error
Hi there,
After the IPA package is created, l get a Waiting for Debugger Connection dialog box in Flash Builder. The debugger will connect after you install and run the application on the device? If will not connect what should I do next ?
Thanks !
Waiting for debugger connection
Packaging FlexMobileTestDriver for Apple iOS has completed successfully. To begin debugging your application, follow these steps:
Make sure device is connected via USB
If the application was previously installed on your device, uninstall it.
Drag and drop the .ipa package into iTunes library.
Ensure the app is checked in the Apps tab for your device in iTunes
Sync the device using iTunes.
Launch the application on the device.
