VPS providers says that flexibility is a benefit of vps account. I would just like to clarify what do they mean when they say flexible since I know that there are hardware limitations and possible program incompatibilities. I hope someone can help. Thank you!
Flexibility is a benefit of vps account but what are the imitations?
A VPS, or rather, a Virtual Private server is a web hosting service that comes as an alternative of the shared website hosting. The most important flexibility attribute is that you can install your own programs and customize it depending on your preferences.
The other advantage that comes with flexibility is that there is no sharing.
This leads to low traffic and therefore, a constant interaction speed is enhanced.
However, you should be privy to the specifications of the VPS you are purchasing to avoid overloading and incompatibilities with other programs.
