poatbel4o
Posted on - 01/29/2012
I have FLIR Infrared Camera software on my Windows XP PC. It was working fine since the last time I used it. But when I try to run it today, the application failed to start. I restarted my computer and start running the program again, but it still failed to start. What should I do to correct this? Please send me some help. Thank you.
Application failed
Cannot create internal object.
OK
FLIX Infrared Camera Software Failed to Start
You may want to try to restore your computer to a restore point before you encounter the problem. To do a system restore, go to Start > All Programs > Accessories > System restore. There might have been a patch that has been updated or corrupted.
If the system restore did not resolved the issue, you can try to uninstall the application via the Control Panel > Add/Remove programs option. You need to do a full restart and advisable to wait for a minute or two before turning the computer back on then do the reinstallation of the application.
Aristono
