Zindagi
270 points
Posted on - 04/24/2011
Hi
I am working on my assignment in ms word.
I have checked all the options given but i can't add flow charts. In MS Excel its very easy to add flow chart but I can't import that also.
Here I need to add flow chart according to the data given.
How can I add,
Please help me
Sahil
How to add Flow Charts in MS-Word?
Hi Dear
Please clarify that what kind of flow chart you want to add so that i can help you through.
If you want to add simple flow chart then you need to follow the steps
1: Insert menu
2: picture
3: Organization chart
By selecting organization chart you can add the chart that represents flow of organization from top to bottom.
This type of flow chart you can add by following the steps i mentioned above
Given example
Zindagi
270 points
Hi Dear
Thanks for your help
Its very informative and helpful for me.
Sorry i forget to mention Multiple flow charts. the steps you have mentioned are useable for simple flow chart but i need to add multiple flow charts. is there any option to add multiple flow chart?
Actually i want to draw multiple flow chart for this data
Sahil
I am sorry dear
I don't have any tip for that
let me try this so i will tell you later
JThomis
120 points
Hi Dear
I understand the problem. For multiple flow charts in ms word there is a special option that is “Object”.
Ms Word takes flow charts as objects not as simple charts.
So the steps required are
1. Insert menu
2. Object
3. Microsoft Graph Chart
Follow this and let me know it helps you or not?
Zindagi
270 points
Dear Thomis
Thanks a lot for your really valuable help. It really works i really want these flow charts
But I need one more favor
Can you please make multiple flow chart according to the given data so that i can understand where i need to change in default data by ms word in graph chart option.
waiting
JThomis
120 points
According to your given data, the chart will be like this according to my suggestion
Zindagi
270 points
Wao
Dear you are superb. awesome. Really it really helps me.
Without your help i cant make my assignment on time.
It really works. I am working on initial level in Ms Office or you can say i am new with Ms Office.
Please be with me to guide me through
Thanks a lot again
Stay Blessed
JThomis
120 points
Its ok dear
If i am available then i will defiantly try to help you dear
Stay blessed
Sahil
Thanks JThomis, I need this too
Because i really want to know that can we add multiple flow charts in ms word or not.
Zindagi, thanks because of you i learn one usable thing
Bye
Nice!
Zindagi you help me too, because of your instruction I found an idea to create a project using MS WORD.
I would also thank to the one who create this article.
