Flutter app not working for VLC.
Asked By 15 points N/A Posted on -
I am using Flutter app which provides gesture controlling of some application such as for windows media player etc. Recently it also provides updated version which support controlling of VLC through gestures. But after updation it is not working for VLC and even stopped working for other apps. Suggest some way to fix this issue.
Answered By 590495 points N/A #183024
At first, I thought the applications on the computer can be controlled by mouse gestures since you said “gestures”. But I was wrong. What you mean by gestures is the actual hand movement in front of a camera or a web camera. Unfortunately, Flutter App is no longer available from the official flutter website because Google already acquired the company.
You can still download it from other websites. Flutter was acquired by Google for US$40 million in October 2013. If the application has a problem after the update and is no longer working, try reinstalling the application. Uninstall Flutter App then click Start, All Programs, Accessories, System Tools, and then Disk Cleanup.
Select drive C then click OK. Check Setup Log Files and “Temporary files”, click OK then click Delete Files. Restart the computer then install the latest version you downloaded. In case you no longer have the installer, download Flutter App 0.7.22.
