FM Genie Scout 12 v1 Beta 1: Error Loading Entity Number 455
Hello I am trying to work with the FM scout 2012 but the problem I am being faced is that I am getting the error in loading and the program opens as normal but only with an administrator.
The error in loading Entity number as showing it to 455 and position of file is being displayed as 24520751 and even database version is 1686 and I am sure with the latest version of FM Genie Scout in which the file is not corrupt and even the string is too long as 10422235.
Dump files are even kept in the same folder FM Genie Scout.
Kindly provide me the solution for the problem.
Thank You.
Error:
Error Loading Entity Number : 455
File Position : 23923204
Database Version: 1686
XML data seems to be corrupt.
Please make sure that you are using the last version of the FM Genie Scout and that the file is not corrupt
If you are sure and still see this message, please send the dump file with information of an error to my site(use 'Report Bug' from menu 'Help and Support') and it will be fixed in the near future.
dump files are kept in the same folder as FM Genie Scout.
Thank you for the cooperation.
Filter Type :15
