FM Radio in Cell phones without handsfree
It is mostly observed that if you want to listen FM in cell phones you always have to connect hands free first, why it is not built-in install in Mobile phones?
You need the wired headset to listen to the FM radio because the wire itself is the FM antenna.
Swap it for a wireless Bluetooth earpiece and you no longer have the antenna, ergo the radio won't work.
You may not have noticed, but you can't even start the radio without a wired enhancement being connected.
FM radio in cell phones is a better opportunity to enjoying the different things about to world at everywhere. Regarding your question why it is not built-in, has been solved to some extent.
Now there are cell phones that are available in the market, you can purchase it from everywhere in the world and can get the benefit of this opportunity very easily. Regarding to your statement there are also some mobiles are in present those want to must use of the hands free. So there is also available the solution of this issue by getting a software install it in your cell phones and enjoy  it without taking or carrying hands free.
