Fmodex Dll Missing Error On Launching Games
Whenever I launch any game, I get the fmodex dll file missing an error. This has been the case for the past two days. I cannot seem to figure out how to move past this. Can I solve this error on my own?
Yes. You can definitely solve this error on your own. You are getting a dll file missing error which is extremely common and generally has a very simple solution. The fmodex.dll file is associated with Firelight.
This dll file is used by the FMOD Ex SoundSystem. So if your game uses this, you will get the error whenever you launch this game. To solve the issue, all you need to do is find this file on the internet. Download the file and place it in the appropriate directory. The location where the file needs to go will be mentioned on the download page. A simple restart after this will solve your problem.
