FN Accessibility Driver is Missing: Error on Toshiba Laptop
I want to know why do i need  fn accessibility driver, i don't know what that means, and my laptop keeps telling me that i am missing that driver, so please explain to me
Hello Agustin,Â
Your Fn Accessibility driver is the driver that runs your Fn key or function key as I like to call it. Â You probably have never used it. Â I think I have only used it once or twice on my laptop. Â There are a few keys on your keypad that have either a different color or a smaller script of writing or a box around the letters. Â Your Fn key would be on the bottom of your keypad and it would correspond with the different format of letters. Â You would press the Fn key and the letter or key and that function would start. Â
A solution to this problem would be to go to the website of your laptop and find the download for the fn accessibility driver.
Hi Augustine,
Thanks for your question. Well, most laptops do ask for the fn accessibility driver. The driver has a great use. It enables you to create a hotkey function using two or more fn keys. It is usually painful to press two function keys simultaneously to activate a function.
It enables you to complete the task with ONLY ONE fn key instead of two or more when required. It can also be used to make fn keys as sticky keys. Means that you need to press the driver key once and then release it. After that you can press the Function key to activate hotkey function.Â
You can download fn key accessibility driver of your laptop. Browse for your laptop and click on download driver from the list of drivers.
