A folder lock Logiciel Mac Software offered today
Hi there!
I want to secure my files in my desktop.
Do you know some folder lock Logical Mac software for it?
Thanks and I would be glad for your answer.
Hi there!
Hello Hirt,
Securing files on the desktop are very easy now. All you need a good and reliable folder lock software.
You can try Lacie PC Lock 1.7. It’s easy to use and secure. I’m also using it and it’s good.
Please follow the link below for the software:
http://www.easyfreeware.com/freeware/logiciel_pc-mac.html
You’ve to download the zip file and unzip it.
Best of luck.
Hello there !!
There are various software available in the market that helps you to protect the files on the Desktop. And when talking about the Mac, then Mac is secured in itself only than also if you want to know the software regarding the Mac operating system then we are having the list of few software regarding the Mac operating system .Do visit the given address for the software:
1. this website contains the list of various application of the folder lock for different version of the operating system environment
2. Â this website will directly leads you to the page that is consisting the folder lock setup for the MAC operating system.
