Folder is not writable to Save file
Asked By 1290 points N/A Posted on -
Hello guys,
I have a scenario here that happens while using Free Commander, when I am in the middle of my work with FreeCommander an error occurred, error message flash my screen, it tells that folder is not writable to Save file,
Please see below the error message for reference.
FreeCommander.exe
Folder is not writable. Save file:
C:UsersRalfAppDataRoamingFreeCommanderXESettingsFreeCo
mmander.ini
With not much experience with Free Commander, I am having a hard time figuring out the cause and solution to this problem, I already search on the internet for some similar scenario I have, but I found nothing,
I am sharing my experience here in hope to get some help,
Thanks in advance.
Answered By 0 points N/A #122626
It seems that you are using windows vista or windows 7 so you cannot just run this application as like windows XP. You have to run it as administrator every time or you can change its compatibility mode to XP by doing as follows:
Go to: C:program filesFreeCommanderXE
And go to the properties of the main exe file of Free Commander. Click on the Compatibility tab and select the first option "run this program as" to windows XP service pack 3. Click OK to exit.
Now coming to the file write error. This error occurs because your user doesn’t have any permission to write this folder "C:program filesFreeCommanderXE"
Go to Program Properties > Security Tab >
Select your user from upper area and then click edit. Now in lower area which is permission area. Select Full control.
Click Apply and then OK.
Now run the program again and you will not see error any more.
