Follow The Steps To Learn How To Backup And Restore
Hi. I am using Windows 7. I have been trying to backup the data and to restore it, but it is not working out. How to backup and restore? Please reply ASAP. Thanks in advance.
Hi. To learn how to backup and restore,follow the steps as given below-
1) Backup-
• Select the start button following which click on control panel
• Select the system and maintenance option
• Click on backup and restore
• Either select the set up backup option or the back up now option or click on create new, full backup option
2) Steps to create a restore point-
• Click on the start menu>control panel
• Then, the system and maintenance option should be selected
• Click on the system tab
• Select thesystem protection option
• Then, click on the system protection option and click on Create
• Type a description in the system protection menu and click on the create option
3) To restore-
• To restore the files, either click on restore my files or restore all user’s files
• Then, browse the files to go through the contents of the files or click on search option after selecting the file to be viewed
Hope we helped.
