Is font view for Nokia Lumina 900 available?
Previously I had S60v5 based Nokia cell phone and Font View was working perfectly.
Now recently I purchased Nokia Lumina 900 and was wondering if font view for Nokia Lumina which is windows based cell phone, available?
Best Answer by Dyer Pearlman
Answered By 0 points N/A #133547
The you had was an S60V5 that is why Font View was working.
However, Nokia Lumia 900 is a Windows Phone smartphone.
I visited the Nokia Ovi Store in order to check for compatibility but unfortunately, I didn’t find the Nokia Lumia 900 among the list of compatible devices which means that you cannot install Font View in your Nokia Lumia 900.
Answered By 0 points N/A #133548
Hello Dixon Eartha,
Currently you cannot change the Font Size in a Windows OS phone.
When reading text on your phone, you can try to turn it horizontally and the text will automatically enlarge.
Also,you can try using the zoom or expand button when reading emails to try and enlarge text.
Here is a link to a forum that discusses similar issues. If you would like to go through the forum you will be more informed about different phones.
