Football Manager Genie Scout 2012 Error Loading Entity Number: 455
I have two problems. First, when I am starting Genie Scout 12, I receive a ban_vertical error message. After that, the program opens an infinite number of internet explorer pages. The program seems normal when I start Genie Scout as administrator. Second, I am not able to load my save games (By using default database!). I find the following error message:
Error loading entity number: 455
File Position: 23923204
Database Version: 1686
XML data seems to be corrupt.
Please make sure that you are using the last version of the FM Genie Scout and that the file is not corrupt.
If you are sure and still see this message, please send the dump file which information of an error to my site
(use 'Report Bug' from menu 'Help and Support') and it will be fixed in the near future.
Dump files are kept in the same folder as FM Genie Scout.
Thank you for the cooperation.
Filter Type: 15.
                         OK
