Football Manager Genie Scout 2012: XML Data Corrupted
Hello experts
I've got a problem. I keep getting the following error with Football Manager Scout 2012. Please help. Thanks in advance.
Error On Save FM scout 2012
Error Loading Entity Number 0
File Position: -1
Database Version: 1686
XML data seems to be corrupt.
Please make sure that you are using the last version of the FM Genie
Scout and that the file is not corrupt.
If you are sure and still see this message, please send the dump file with information of an error to my site (use 'Report Bug' from menu 'Help and Support') and it will be fixed in the near future.
Dump files are kept in the same folder as FM Genie Scout.
Thank you for the cooperation.
Filter Type: 7.
