My Incredible 2 phone is prompting me to delete old messages, contacts, calendars or call logs due to 'memory has become high in database'. But when I try to do so, the specific app along with all the apps are force closing. Can anyone help please?
Force Close problem with error message on Incredible 2
Hello Warren Donaldson
Here,you are facing a problem with low space on memory problem.Force closing is because the system has become slow because,more use of memory..Even android phones provide more space,it shows many problem with low space .Actually you have to check your phones's root folder whether its memory is full or not.After that you will have to clear all the cache from your all applications.Also there is a folder named data/data where all the information about applications and their components are stored and its always limited to 150MB.If you could locate it,it will be easy for you to remove unwanted files and data.You can also use root explorer to find how much space is free in it.
Also,Not Enough Space is a application used to find the available space and also can remove unwanted applications.
Actually ,Applications like google earth,Facebook,Gmail,uses more space.Its better to move these applications to SD card.Hope this information helped you.
The HTC DROID Incredible 2 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM, CDMA, HSPA, and EVDO technologies. It was announced to the public and released on April 2011 measuring 120.7 x 64 x 12.2 millimeters and weighing 135 grams. It uses mini-SIM card. It has S-LCD capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution.
It supports multi-touch with HTC Sense UI. It ships with Android 2.2 Froyo upgradable to Android 4.0 Ice Cream Sandwich powered by Qualcomm MSM8655 Snapdragon S2 chipset, 1 GHz Scorpion processor, and Adreno 205 GPU. It supports microSD expandable up to 32 GB. It runs on 768 MB RAM with 1.1 GB internal storage.
The primary camera supports 8 megapixels with AF and dual-LED flash and supports 720p video recording at 30 fps. The secondary camera supports 1.3 megapixels. It has 3.5-millimeter jack featuring SRS WOW HD, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP and EDR support, GPS with A-GPS support, stereo FM radio, and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors.
The pre-installed web browser supports HTML with Adobe Flash support. It runs on removable Li-Ion 1450 mAh battery with standby time up to 361 hours and talk time up to 6 hours 30 minutes. It is available in Black, Red, and White colors. If that’s the problem you are having, try factory reset.
If your phone runs on Android 2.2 Froyo, on your phone, go to “Settings”, “Privacy Settings” then “Factory data reset”. If your phone runs on Android 4.0 Ice Cream Sandwich, on your phone, go to “Settings”, “Backup & reset” then “Reset phone”. Before factory resetting, make sure to back up your entire phone’s data.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
