Force the users to login into the domain credentials
Hi Experts,
I have a domain which is configured using Windows Server 2003 and clients are Windows XP Pro. It’s possible to login with the domain user id. But of the users don't login into the domain; they are login into the local machine with usernames which are NOT in the domain.
They get access to files which are stored on the server, by using the server's IP address in shortcuts and scripts. It appears to me that security on the server is not properly set or I must have been partly disabled, to allow this unauthorized access.
Can you help me in force the users to login into the domain credentials?
Thank you very much.
