Forefront Protection 2010 for SharePoint – Post Install Issue
Asked By 100 points N/A Posted on -
I had a recent customer who seemed to successfully install Forefront Protection 2010 on Sharepoint for their own Sharepoint 2010 farm.
However, we have now encountered a slight issue; each single WFE is assigned a non-SharePoint IIS website; which is utilized by their system to monitor the IIS functionality.
I once went to this “test” site and was greeted with the posted error (HTTP Error 500.0 – Internal Server Error).
serve error in application "test"
Best Answer by Bolton butks
Answered By 0 points N/A #190572
Hello Martin,
To resolve that issue, you will need to reload the web page. You can do that by clicking the refresh/reload button, or you can press F5, or trying the url from the address bar again.
Or you can come back later for the site may be down for a while.
Nicke
Answered By 0 points N/A #190573
Hello Martin Thompson,
This problem has occurred for network problem. First, check your internet connection. If the connection is slow then this kind of error message appears. You can also check that your browser is permitted to access the web. If the problem is a network connection, you have to talk with your ISP. Otherwise, you can try a different browser.
You can check your internet connection speed at http://www.speedtest.net.
Bolton butks
