T McDuffy
25 points
Posted on - 09/22/2016
If you have an iOS device and you enter a wrong password for 6 times, your device will be locked and disabled. That means all the data in it will be lost, until and unless a back-up is done. What to do if i forgot my passcode on my iPhone?
T Hill
40 points
Forgot My iphone Code And Cannot Access My Phone Now.
iPad, iPod, iPhone devices have a feature to lock themselves when 6 wrong passwords are entered.
The entire data present in it has to be removed in order to solve the issue. If you have not taken a back-up, then you will have to lose all the data to retrieve your device.
TO ERASE THE DATA FROM iOS DEVICE:
1) WITH iTunes
Your device must be synced with iTunes to restore your data.
Open iTunes using other device and enter the passcode or go to recovery mode.
Wait till iTunes get sync with your device and backup process starts.
When the process is done, click Restore.
Then click Restore from iTunes device.
Select the backup on the basis of size and date.
2) WITH iCloud
Using another device, go to www.icloud.com/find
Login with your Apple ID.
From the appearing list, select the device to erase.
Press erase.
You can restore by clicking Restore from a back-up.
3) WITH RECOVERY MODE
Connect your device to another one, force reboot it. Press the wake and home buttons simultaneously.
When you see the Apple logo, and then the recovery mode screen, release the buttons.
Click ‘restore’.
From the options displayed, choose Restore.
This will download iTunes. Wait till the process gets completed. Then you can use your device.
