Forgot my login password what should I do
Hi Maverick,
Do you mean the Administrator’s Password or Account Password?
If in case it is your Admin password that you have forgotten: Reboot computer into Safe Mode. Select the Administrator Account, when prompted with a password, try to click enter. Once logged on to Administrator Account, click Open Control Panel and User Accounts. Select the account to click change the password or remove the password of the account. There are also other commercial utilities available for password recovery. Visit the following links:
Just try visiting these supports.
Yes dear friend you have got a answer for recovering your operating system password.You can reset the system password by reinstalling the operating system from a CD disk too .Now I am describing recovery process of a online account like email,Facebook or others. Maximum sites have a password recovery option. So try to check it.
Please go to your site on which you have account.Then click on login or there may have a login page on homepage.On the below of Sign in or Login icon you will find forgot your password? or can not remember password? or same phrasesn.
Please click on that link.
If there is no link like this then inter your ID and a anonymous password and click Login.
Then you will get a message like this: "Invalid user ID or password,please try again." then try to search there a forgot password link. After clicking the forgot password link,you will be asked to provide some information.Compleate the process and reset your password.
There are several passwords that we may have created to secure our accounts. And there are instances that we cannot help but forget some of them. Now, the question is which password did you recently forgot?
Is it a password for your email, gaming account, or the actual administrator’s password you are using for your computer so that no one can access it but you?
The reason for these questions is because to recover your passwords there are several ways that you need to try and it depends on which password you will need to reset. Now, I’ll assume that you may be referring to your administrator password. If that is the case, I’ll also need what Operating System you are actually using.
If it is a Window which is commonly used then all you have to do is try restoring your system. Meaning, you will have to go back to a certain restore point or date before the password was created, however, this is not 100% workable. What is really workable is by recovering your system or putting it back to its original settings like the very day you purchased it. However, the problem with system recovery is that you will lose your important saved files.
Nevertheless, there are ways for you to back up those files, and you should be ready with an external storage device that have enough space for your important files to back them up before doing the system recovery.
