Forgot password for 2GB sd memory card in nokia phone
I am using a nokia c2-03 phone. I use a 2gb sd memory card with it. I have kept a password for it. Now I forgot the password. I'm now struck with that memory card. Please some one give me a solution to recover the password.
I need it urgently as it has some important information.
Best Answer by Tamara Francic
Answered By 0 points N/A #160574
Navigate to the File Manager of your mobile phone, and then go to the Settings and select the System Folders. Under the System folder of your phone, search for the file MMCSTORE and send it to your computer through IR or Bluetooth and then launch it using your notepad. You can see the password of your mmc card on that file.
If this doesn't fix the issue, contact or go to Nokia Services.
Answered By 10 points N/A #160575
Thank you very much. I have experienced the very same problem with my 4 GB micro sd memory card. I had assigned a password and forgot it! The card contained some important files and I was very worried about how to recover it. Thanks to the expert for solving this problem. And thanks to techyv.com too.
