Forgot The Password Of PDF? Learn How To Open Secure PDF
Hi. I have recently started using PDF and I am not very sure about how to view a PDF in case I forgot the password to it. How to open secure PDF? Please reply ASAP. Thanks in advance.
Hi. To learn how to open secure PDF, use PDFUnlock by opening its website that is, pdfunlock.com which can be used to unlock files for free. However, there is a limit to the file size which is 5MB. The file can be uploaded by browsing it from the PC and in case the file is present in Dropbox or Google Drive, then you will have to log into the account and then upload the file. Then, click on the unlock button and after the file gets uploaded after a few minutes, the software will send the converted file which can be saved on the PC on an easy-to-access location. Open the file and then click on properties from the file menu following which ensure that the security method indicates no security.
Alternatively, you can open the browser Google Chrome and then browse the PDF file and then open the locked file. Right-click on the icon of the file and select the print option. Next, save the file as PDF to the location where it can be accessed easily. Then, using any PDF reader, the file which has just been created can be opened without entering any password.
Hope we helped.
Notifications
