Forgot your password on iPhone: Procedure to follow.
I have secured some applications on my iPhone because of my children. But I too forgot my password on iPhone. What steps should I follow to solve this problem?
Solution 1:
Step 1: You can backup your iPhone by synchronizing it with the same computer which you have used before.
Step 2: Select iPhone in the Devices list.
Step 3: Click on Summary at the top of the screen.
Step 4: Synchronize it.
Step 5: Select Check for Update option. The new version is available.
Step 6: Choose Restore and follow the instructions.
Step 7: Select "Restore from iTunes backup."
Step 8: Select your device for backup.
Solution 2:
Go to icloud.com/find using another device. Sign in with your ID. At the top of your browser window, open All Devices. Choose the device that you want to erase. Select the option of Erase. Click on the option of restore and create a new passcode.
Solution 3:
Connect computer and iOS device and then force restart. Press and hold at the same time Sleep/Wake and Home button. Hold it till you get the recovery screen.
