bellaross
Posted on - 12/07/2011
What would you do if you accidentally placed an incorrect email address in your MySpace account and you changed your email account to the email address that you used in you MySpace but you already forgotten? And yet, you still want to keep your MySpace account.
Forgotten Email Account in MySpace
Bellaross
In the scenario you mentioned, there is only one option by which you can retrieve your MySpace account.
What you require is that you create a SALUTE, and send them this salute, and they will give you back your profile.
This is the way to create the salute.
1. Take a piece of paper and write MySpace and your MySpace friend ID or your MySpace vanity profile ID.
2. Take a clear view of your face photo holding the paper in front of you.
3. Now click on “Contact MySpace”, choose Log in as the Category and Here is my Salute as the sub-topic. Be sure to attach your salute and make sure the image file is under 4 MB.
4. Now explain why you are sending a salute in the Question box.
Email to [email protected] with your salute as an attachment and they will give you log in information to your account.
PT
That will be a high case of forgetfulness, but since you do remember the email then you will not be able to use your MySpace account, and neither your email account since you had changed the email address to the email you used for the MySpace account that you have just forgotten.
I do not know why you will want to change the email address to some other address, because you will be risking losing any important emails that you have in your email account. You could have instead changed the MySpace email address that you had used to your email address that was functional to avoid the risk then you just exposed yourself. I am just hoping that you did not have any important mails in your mail box because that will be a tragic loss.
Regards
Thompson Locker
