..forgotten password for psp vita
I own a PSP vita and forgot my password..now I've reset the vita and entered new account info for Sony online and it won't read my memory card…how do I fix this?
A. You just need to reset again your lost password.
These are the following steps on how to reset passwords in PSP vista:
1. Go on settings, and then click system settings.
2. Restore default setting and click yes.
3. When it turns off, don’t worry about it.
4. Turn it again, choose your language and choose the time.
5. Go on security settings, and change your new password.
B. If your memory card is not working, these are the things that you need to do:
1. Just relax and try another PSP memory card, try to see if its work.
2. Format memory card from a card reader but be reminded that all the data will be lost.
These are the different steps on how to format the PSP Memory card:
a. Push HOME button on the bottom left of the face of the unit.
b. Use arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
c. Click on the "X" button; scroll up and down as needed until you find the Format Memory Stick. Click again on the “X” to select that option.
d. The Sony PSP will now confirm that you want to reformat the memory card, choose yes and it will format in just a few seconds.
If your Sony PlayStation Vita cannot read your memory card, it is possible that your game data or its contents are corrupt or damaged. There is no solution to fix a corrupt game data except to format the memory card so it can be used again to save your game progress.
To format a memory card in PlayStation Vita, insert the memory card to be formatted in the system then go to Format and then select Format Memory Card. After this, just follow the succeeding instructions on the screen. If you have forgotten your password for your PlayStation Vita, you can always replace it by resetting your master account password.
To reset your password, connect to the internet then go to Settings, PlayStation Network, Sign In, and then select Forgot Your Password. If you are automatically signed in, sign out. Next, enter your Sign-in ID or the email address you used to register your account then your date of birth and then select Next. After this, check your inbox. They will send you the link to your email address.
Open the link from the email. You will then be directed to a page where you can enter a new password and confirm it. After this, sign in to your account using the new password you created.
