Forgotten Security Code on Nokia 3230
I enabled my Nokia 3230 security code for security purposes.
When I want to remove the code, I realized I have forgotten the code.
How can I remove it without typing my password?
Do I need any software to fix it?
Please help.
Best Answer by Jackson Day
Answered By 0 points N/A #123576
To reset the security code Nokia *#7328748263373738#
Use listed website to generate Master Code by using your IMEI number.
The above website is Nokia registered so don't worry about entering your IMEI number. For this you must have your Mobile box. At the bottom of a mobile box there is written an IMEI number which is unique for all mobiles of all companies.
This will help you in getting the master code. When you get the master code just enter it in your mobile .The code will be reset to its default.. 1234. Then you can use your mobile with new security code.
Hope this will help you in breaking your security code.
Thanks in Anticipation.
Answered By 40 points N/A #123578
Hi ,
Connect your Nokia phone via data cable and by using Nokia PC suite click on updater software version, if no update is available just click on repair and then follow the steps to successfully reset your security code in Nokia,
There are many administration tools for Nokia available in the internet, please be careful while using it,
I suggest you contact your Nokia customer care and take your phone to your local Nokia care Centre and they will repair it for you. That will be just the best and convenient what doing all these stuffs by yourself without proper knowledge can cause PERMANENT KILLING of your phone, and stages such as data lost error and other exceptions.
Use this link
For Nokia's forums answer FAQ's,
Hope that helps.
