Can someone here enlighten me on what this specific error message from webpage error is referring to? I cannot submit the form because of this and I need this to get fixed.
“The form cannot be submitted because of an error.”
Please help. Thanks in advance.
There is some javascript error in the validation process of the text box or radio button or any other form field.
1. Check if there are any error messages displayed on the page after submission.
2. Manually check to see if you have missed out any mandatory fields.
3. Another possible issue may be a JavaScript issue, which cannot be rectified from your side. You should get in touch with the owner of the webpage and get help.
4. These kind of problems might also occur because of browser compatibility issue. Try this form from different browsers. This might help in most times
