Form error with Rubik administration theme
Hi all,
I'm running Rubik for my administration theme. If a form is submitted without filling in a required field, say at /node/add/story, Drupal will provide an error message saying that the "Title field is required" and it will reload the form again with the required fields outlined in red.
The problem is that the error message and the form, along with the outlined fields, are not displayed in Rubik. They pop up in the default front-end theme. The form is viewed, like totally wiped-out, in the front-end theme. I need to solve this but I haven’t found any solution for this. Any help would be appreciated. Thanks for the suggestions.
