rona25
Posted on - 09/19/2011
Someone could help me,
Please help me with this one. Am I importing something that adobe after effects does not support? It took me many days now and still not fix. Is the problem is within the file? Just like perhaps some files are deleted or corrupted like the TGA files.
After Effects error: Photoshop file format error – unexpected end-of-file (-39).
( 45 $ 35 )
Hope you could help me.
Formats accepted with adobe after effects.
After effect problem can be solved easily. It is a tool in graphics design or Photoshop. It helps you to select a particular area with same format and give you that opportunity to go and edit that particular area. It is a small file in Photoshop library.
If in your computer you install some similar application program in a same time then uninstall one program, this problem occurs. Similar application share similar file they have and uninstall one program can take that similar file with it. So this error shows.
If you want to solve this problem you need to install plug-in. You can easily find this plug-in on internet. Installing missing plug-in will solve this problem. You can also visit http://supportdownloads.adobe.com/thankyou.jsp?ftpID=4292&fileID=4003 for find missing plug-in.
