FORTRAN runtime error occurred file ‘input1.txt’ does not exist
40 points
Posted on - 11/03/2012
Hi professionals,
Could you help me in this issue?
I have installed Windows 7 64 bit version in my PC. I’ve a good experience with FORTRAN as far as DOS is considered. I need use Simply Fortran, Is there any manual or tutorial that I can use?
I have been able to compile. But Simply Fortran does not recognize my data files when I attempt to run my program. I get an error message stating: "FORTRAN runtime error: File 'input1.txt' does not exist. Press any key to continue. ”
Could anyone suggest any answer? I’m waiting to get a response from your side. Thanks a lot in Advance.
