I have downloaded the “Gears of war” in ISO file the size is 7.41 GB (Giga Bytes)
Error number: 0x80040702
Description: Failed to Load DLL: FirewallInstallHelper
Setup will now terminate.
OK
This error message shown when I attempt to install it after 15 to 20 minutes
If somebody knows to fix this error please let me know I need your assistance.
Thanking You.
Found error while installing Gears of war
Hello Oliviarwilkes,
It seems that there are other people with this problem. I will help you with this one.
– Put the CD in and allow it to load.
– Do not install the game yet, when the auto run window pops out, exit.
– Use the search tool in the CD and find the “FirewallInstallHelper.dll”. Leave it for now.
– Go to your System 32 and drag the file here.
– Install the game. If prompted to uninstall first, click Yes. If prompted to delete all user content, click Yes.
– It should install fine.
Hope this helps.
