Hi experts,
I recently purchased a Samsung Galaxy Mini mobile phone. To get a free mobile hot spot I used different gadgets, they all work well initially, but after some days they stopped working. One of my friends recommended me to use FoxFi gadget. If anyone has ever used this gadget, then inform me about its problem/ errors and benefits. I am looking for the information about FoxFi apps for the Samsung Galaxy Mini. I am waiting for a quick reply and positive response.
Regards
Is foxfi app for Samsung Galaxy mini good or not?
FoxFi is a simple application, designed to work around your WiFi hotspot system.
FoxFi enables you to work with your tablet, your computer and any other application that requires a WiFi connection.
You will not be charged for WiFi hotspot use by your carrier. In fact, your carrier will not notice that you are using a tad more data.
FoxFi application is considered to be safe; it also works properly on Samsung devices and HTC phones.
Download FoxFi from this link
I hope this is helpful.
If you want to try it on your Samsung phone, go to FoxFi on the Google Play store and download it. The latest version at the moment, FoxFi 2.20, requires Android 2.2 Froyo and higher. Before downloading the app on your device, check the page for feedbacks from users who already used it.
This will give you an idea if there are problems with the application and if other users love it or hate it. FoxFi is an Android app that will allow you to use your Android device as Wi-Fi hotspot and allow other devices to connect to the internet. Unlike other apps that require phone rooting, FoxFi does not require any rooted device to work.
For more information, visit the FoxFi Home page.
