Foxit Reader Missing Component Found
When I installed Foxit Reader in my computer system, I received changed error. When I close a program, sometimes the file missed. Please tell me if it is due to a virus. I installed antivirus and then scanned my system, then such type of errors appears.
There is a certain component (lang_tr_tr.xml) missing for Foxit Reader. You might need to download update from our website to display your file correctly.
Do you want Foxit Reader to get more information about the component and show up the Download Manager?
Note: this will require internet access to Find server.
Yes No
