Foxy Previewer – Problems during Load
Hi all
I have found this odd problem in Excel Files made by export from FoxyPreviewer.
What should I do now? I need to solve it quickly. Please give a solution.
Thanks a lot.
Problems During Load
Problems came up in the following areas during load:
Worksheet Setting
This file cannot be opened because of errors. Errors are listed in: C:Documents and
SettingsAdministratorLocal SettingTemporary Internet
FilesContent.MSOF81ABAB.log.
                                                        OK
Also I cannot discover the file Content.Mso.
Answered By 10 points N/A #154508
Hello Clive,
The error you are getting when you are trying to export from FoxyPreviewer usually occurs in the event when you use a number format in the Office Spreadsheet or a PivotTable list which is not supported by Microsoft Excel. To resolve that issue, you will need to make sure that you are using a number format that is supported.
After you have changed the number format, exporting for FoxyPreviewer should work just fine without bringing the load issue that you are getting right now.
But if the problem persists, you may need to uninstall the application and reinstall it for it may have bugs that are causing the error to happen.
Carl
