Free and good template for student survey
Am a physics teacher and am searching for a template for student survey which is free but it must be good enough for my physics experimental diagrams.
As you are a teacher, you'd be needing the template to be a little decent and sophisticated. I am pretty sure that questionpro.com can really help you with your work.
Questionpro normally offers you a pretty wide range of free templates for the most common surveys. Obviously, student surveys are a part of their lists.
Another option is to check in to surveymonkey.com which again is a leading and free website for downloading templates for educational purposes. I'd recommend you to try both the websites and then decide to choose one.Â
Aracelirystal,
There is nothing better than to find out that your students are gaining information from your teaching. The easiest way to show these results is through a small survey. The next objective is to be able to tailor your surveys to the information or projects you are discussing.
An easy product to use is software from "createsurvey.com". All you need to do is download the software and begin making surveys. Once you have the program it will help to tally the information you receive back.
