Free anti-virus software on the Internet
Yes, there is a free anti-virus that can be downloaded through internet and that is AVIRA. Just go to any internet browser then search avira anti-virus free download or just simply type the website www.avira.com/en/downloads. You must choose theÂ
Avira Free Antivirus then click download, don't choose Avira Premium. After downloading you can now install it. That is just for free.
All you need to do is just update this software if needed. Remember to have an internet connectivity in order to update the
Avira anti-virus.
Okay enjoy..
There’s another anti-virus that is free and reliable. Well it has good reviews too. Its Avast Antivirus. You can download it free on their official website. Simply type in https://www.avast.com/en-in/index and select Avast! Free Antivirus.
After the download is complete, If you have an antivirus installed before remember to uninstall it completely before installing Avast. Clean the registry for leftovers. I suggest using the tool CCleaner because it’s also free and easy to use.
Remember to update Avast regularly to avoid the risk of Viral Infestation.
Good Day, enjoy!
