Free audio converter is needed
Hi !
i am looking software that will convert .mp3 file to .cda. Not all players will play. mp3 files and i have 200 files from one study which i need to convert to something that will work on home players.
Hi !
Hello Jedel,
Actually this is not possible to convert mp3 file to cda file. Because you know cda is not actually a file type, but just a representation of the track on the audio cd. What you can do is to convert the files to wave file.
You can easily do this by using Nero. Pretty much all modern cd authoring programs will allow you to directly drag and drop mp3s into the audio CD layout and will convert on the fly to cd audio while burning. If you don't have Nero then you can easily burn audio CD on online by going to this link.
Musicmatch Jukebox may also be a solution for this problem.
In audio files, CDA (.cda) stands for “CD Audio”. It is the file extension for the CD Audio shortcut file format which you usually see on audio CDs. This file refers to the audio tracks on a CD. This file is actually just a shortcut to the tracks and does not contain any audio.
Now, if you have MP3 files and you want them to convert to the CDA format, the only way you can do it is to burn the files as audio CD on a blank CD. You cannot convert the MP3 files to CDA and save them on your hard drive because CDA is supported only on discs. It requires a physical disc to save the audio tracks.
To burn your MP3 files as audio CD, you can use ImgBurn.
