Free automatically sweep privacy software
I am very concerned about my privacy when I am using my computer because it is shared by a lot of people. So, I wanted to know if there is a software that clears all the privacy data once I am done using the computer, and leave no trace of me at all.
Best Answer by Dyer Pearlman
Answered By 15 points N/A #135277
Hi Isabellartd ,
 Yes it is a good practice to erase history before leaving the computer. Otherwise you will be at a great security risk. The privacy eraser software allows you to erase all traces of your Internet and computer activities. It can remove browser cache, recently visited files, history of web browsing and cookies. Here is the link to download privacy eraser tool. https://internet-privacy-eraser.en.softonic.com/
Another links
http://www.cleanersoft.com/free_privacy_eraser/privacy_eraser.htm
Hope this is helpful.
Answered By 0 points N/A #135278
Hello Isabellartd,
I understand your quest to secure your operations on a shared computer. I will give you tips to protect your data on a multi user computer.
1. If you are the owner of the computer, you can create another account for the other users and give them limited rights.
2. You can use a password for your account and persuade the other users to have their password.
3. Log off your account when you are not using it. This way no one can access it
As an added security measure try to keep your antivirus software and spyware blocker up to date.
