Free AVI to MPEG2 Converter Mac
I have few AVI files which need to be converted to MPEG2, Is there any AVI to MPEG2 Converter Mac available for free. If so please help me by sending the download link.
Hi Darlene,
I believe I will be able to help you solve your query since it has been experienced before and solved. What you need to do in this case is to go to the web and download the software Video converter for Mac.
You will find it on this url. The software can also be downloaded to windows and this is how it works;
Once you download the application to your computer and install it, open it.
Select your video files that you want to convert and drag and drop to the files to the application.
You can then choose the Mpeg-2 as the output format. You will choose it from the output format area.
It should be good to go.
I hope this solves your query.
